# TinyCam Live View Failures
**URL:** <https://forums.wyze.com/t/tinycam-live-view-failures/198593>\
**Category:** Cameras\
**Tags:** cam-v1-v2\
**Created:** [October 8, 2021, 12:34pm UTC](https://forums.wyze.com/t/tinycam-live-view-failures/198593 "2021-10-08T12:34:55Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![cgav34](https://sea2.discourse-cdn.com/wyze/user_avatar/forums.wyze.com/cgav34/32/47748_2.png) [@cgav34](https://forums.wyze.com/u/cgav34)\
**Post date:** [October 8, 2021, 12:34pm UTC](https://forums.wyze.com/t/tinycam-live-view-failures/198593/1 "2021-10-08T12:34:56Z")
</div>
Trying out TinyCam Free before deciding on purchasing pro or not…
I set up two v2 cams and a v3 cam.
When checking each camera’s “Camera Status”, through its settings menu, I’m able to see the live feeds fine; however, when in live view:
- The v3 camera doesn’t display at all, and after a while displays either **P2P failed to start session (AV\_ER\_TIMEOUT)** or **P2P failed to start session (AV\_ER\_TIMEOUT\_DISCONNECT)** Cam firmware version is 4.36.3.19.
- One of the v2 cameras displays for maybe 30 seconds, then cuts to the black screen with camera logo, then comes back maybe 10-30 seconds later, displaying live feed for another 30 seconds or so before repeating the process. It will also briefly display colored static occasionally. When it’s displaying, fps range 0-15 and KB/s range 0-115. Cam firmware version is 4.9.7.1068.
- The other v2 camera seems to work pretty well. Only issue is occasionally displaying colored static briefly. FPS range 5-18, and KB/s range 20-120. Cam firmware version is 4.9.7.1068.
Camera channel numbers correspond to how they’re listed.
Any ideas?
**Author:** ![Customer](https://avatars.discourse-cdn.com/v4/letter/c/e19b73/32.png) [@Customer](https://forums.wyze.com/u/Customer)\
**Post date:** [October 8, 2021, 11:50pm UTC](https://forums.wyze.com/t/tinycam-live-view-failures/198593/2 "2021-10-08T23:50:15Z")
</div>
How does the regular Wyze app do from that same device and/or same location? TinyCam seems more sensitive to poor WiFi connections than the Wyze app is (although I sometimes think that’s because the Wyze app just waits longer before failing).
**Post date:** [October 9, 2021, 3:53pm UTC](https://forums.wyze.com/t/tinycam-live-view-failures/198593/3 "2021-10-09T15:53:05Z")
</div>
The v3 cam has a lot of issues with lagging and freezing in the native Wyze app. Both of the v2 cams seem to do just fine in the native Wyze app.
**Post date:** [October 9, 2021, 11:51pm UTC](https://forums.wyze.com/t/tinycam-live-view-failures/198593/4 "2021-10-09T23:51:42Z")
</div>
Okay, then see if the exact same V3s perform better when you move them closer to your router. It could just be a signal strength issue.
**Author:** ![supergrant](https://avatars.discourse-cdn.com/v4/letter/s/54ee81/32.png) [@supergrant](https://forums.wyze.com/u/supergrant)\
**Post date:** [February 7, 2024, 1:38pm UTC](https://forums.wyze.com/t/tinycam-live-view-failures/198593/5 "2024-02-07T13:38:18Z")
</div>
I know this was old but since I finally solved mine today thought I’d try to help. Every time I turn my tablet on I immediately run tinycam. Therefore, the app never got a chance to update. Updating solved the issue for me.
Of course, wyze could just use their price increases to make a multi view option in the app so we wouldn’t need tinycam.
