Im having trouble with the Timer App. I had a water leak with my water heater and while I’m waiting for delivery of the new one, I placed a large rectangular plastic bucket under the WH and placed a pump in the bottom of the bucket to evacuate the water. Now, I have plugged the pump into the Wyse plug and I wanted the timer to turn the plug on, run for one minute and turn off. I need this to happen automatically every hour. Does anyone know how to do this?
The built-in Timer on a Wyze Plug is a one-shot countdown, so it will not repeat every hour on its own. Easiest path for a 1-minute run each hour is an Alexa or Google Home routine that turns that plug on, waits one minute, then turns it off, set to repeat hourly. If you want to stay inside the Wyze app only, you would need a pair of Schedule rules for each hour (on at :00, off at :01), which is a lot of rules for a temporary pump setup.
