Time-stamp and livestream skipping back and forth in a loop
Has anyone encountered in the livestream (specifically via the web portal) the stream being “stuck” in micro-time loops?
On one of the CamV3 cameras I have what is happening on occasion is that I will see the image skipping back and forth a few seconds, and when I look at the time-stamp in the corner, it shows, for example:
10:05:30
10:05:31
10:05:38
… :32
… :38
… :35
… :32
etc
etc
and then it eventually skips to a new segment of time and repeats that loop-like issue.
I haven’t noticed it happening on any other cameras.
As with anything related to going full-screen on a particular camera’s livestream, it’s that much worse when going livestream.
Any ideas?
For what it’s worth, here is what I would try:
  1. Power off the camera for 5 minutes
  2. Power on the camera
  3. If using an SD card, format that bad girl
  4. See how it goes
Best of luck,
Known1
Hi @Known1 .
Thanks for the reply. The camera is at a different location than where I am when the issue sometimes happens, and by the time I get there, it has returned to normal… like now, as we “speak”. This is an intermittent, but repeated issue.
