Thermostat - No longer following Schedules
I just returned from a several week trip. Prior to the trip my thermostat had been working fine, following the few simple schedules I have, mainly just what temp to use in the morning, evening, and night time.
During my time away I had set the thermostat to “Hold” at a consistent temp, and that also worked fine.
The problem started when I returned and turned off the “Hold” and tried to go back to using my Schedules. The thermostat seems to be ignoring the schedules now. It lowers or raises the temp at seemingly random times. Even If I manually set the temp, at some random time the temp will be changed to some random temp.
I’ve rebooted the unit several times as well as deleted the previous Schedules and set up new ones, but that didn’t help.
Any advice?
I finally got the schedules to work again. Had to do a hard reset of the thermostat, and set it up from scratch again. :roll_eyes:
