Thermostat incompatible
My app said my thermostat is incompatible. Gas central heat and A/C. Trane is the brand. Here is where each wire is placed. Any work around a?
Solved. I made an error in the wire assignment on the setup page in the app. Because R and Rc were both used via one wire and a jumper, I listed both. Turns out only the one with the wire feeding into it is to be identified in the setup portion of app. System is working great.
