I want the spotlight on my battery cam pro totally disabled but in settings under spotlight there is not a toggle switch to turn on or off when motion is detected
I don’t have a BCP but on my other models with spotlight, you just change it from “auto” to “manual” and it will no longer turn on unless you tell it to.
Welcome to the Forum, @Shooter5500! ![]()
I don’t have one of these and don’t know if Wyze has changed the UI since this product was introduced, but their official unboxing video indicates that there should be a “Motion” toggle in Spotlight Settings. What do you see on that screen? Sharing a current screenshot might be helpful.
There is no toggle on motion but I have found the solution. By toggling off the daylight to dark switch it turns off the motion activated light on.
Thanks for the responses.
Keep in mind that also disables IR night vision mode. If you have enough ambient light then that shouldn’t be an issue. There is nothing under the “spotlight settings” menu?
