# Temporary set up at different location
**URL:** <https://forums.wyze.com/t/temporary-set-up-at-different-location/5667>\
**Category:** Cameras\
**Tags:** support\
**Created:** [July 12, 2018, 9:11am UTC](https://forums.wyze.com/t/temporary-set-up-at-different-location/5667 "2018-07-12T09:11:34Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![mamazj65](https://avatars.discourse-cdn.com/v4/letter/m/f4b2a3/32.png) [@mamazj65](https://forums.wyze.com/u/mamazj65)\
**Post date:** [July 12, 2018, 9:11am UTC](https://forums.wyze.com/t/temporary-set-up-at-different-location/5667/1 "2018-07-12T09:11:34Z")
</div>
Hello,
I’m trying to set up my Wyzecam at my daughter home temporarily. How do I get it to connect to her Wifi using my current login info? Thank you in advance!
**Author:** ![K6CCC](https://sea2.discourse-cdn.com/wyze/user_avatar/forums.wyze.com/k6ccc/32/1591_2.png) [@K6CCC](https://forums.wyze.com/u/K6CCC)\
**Post date:** [July 12, 2018, 9:16am UTC](https://forums.wyze.com/t/temporary-set-up-at-different-location/5667/2 "2018-07-12T09:16:25Z")
</div>
Connect your phone to her WiFi and then run setup on the camera.
&nbsp;
**Author:** ![Loki](https://sea2.discourse-cdn.com/wyze/user_avatar/forums.wyze.com/loki/32/1595_2.png) [@Loki](https://forums.wyze.com/u/Loki)\
**Post date:** [July 12, 2018, 1:52pm UTC](https://forums.wyze.com/t/temporary-set-up-at-different-location/5667/3 "2018-07-12T13:52:48Z")
</div>
+1 what K6CCC said. More specifically…
1. Connect to her wifi with your phone
2. Log into the Wyze app on your phone
3. Press the setup button on the camera and listen for "Ready to Connect"
4. Proceed with the regular setup procedure
5. (You don't need to delete the camera from you Wyze app first)
When you want to return the camera to your home, follow the same procedure again at home.
