I no longer see where to add or delete tasks. The ones I have setup are not working either which is a real PITA when i want to quickly disable MD in the house if I swing by there during the day
Tasks are now called shortcuts. From the home screen, tap the three dot (…) icon, then Edit Shortcuts.
Thank you, I deleted the ones I had and setup new ones. Maybe the new ones will work. There is still no indication if the feature is on or off which would be really nice.
That’s because shortcuts are not states, they are actions which either completed successfully or they didn’t. There would need to be some separate display of the on/off state for various things. There are some posts in #roadmap related to that if you’d like to go browse over there for it.
