can I run my cam pan through s7 hotspot, or is there another possibility to take the cam pan on the road. Sometimes there may be free internet service sometimes not but I always have internet through my s7.
Thanks for any help.
J
You’d have to set it up again with the hotspot, but yeah, there’s no reason that shouldn’t work. Even if it disconnects from the hotspot for a bit, it should continue to record if you’re using it with an SD card, although if power gets cut, my understanding is that sometimes it may not start working again until it’s able to connect to the internet again. But your hotspot would allow it to connect.
