Syncing time
so i think it makes sense to post this here…
i just had a quick question (if anyone happens to know the answer), ABOUT THE SYNC TIME FEATURE WITHIN THE SETTINGS OF EACH CAMERA- when you sync time, are you
-syncing it between that camera and your phone? (that’s what I”m assuming) or
-does it only sync the one cam you clicked? or-does it sync the camera to other cameras?
-if that’s the case, wouldn’t there potentially be a lag (depending on internet) STIL BETWEEN CAMERAS?
any answer will be helpful
What about what the Help Center says?
