As I was testing my new Outdoor Cam, I noticed that once the Cam is setup, if you accidentally press the sync button on the bottom (or if your toddler does), the Cam becomes disabled until you restart it with the physical switch. This seems like an odd kill switch. Anyone else notice this issue? Seems like the sync button should be a long-press, or maybe there’s the ability to disable the button once it’s set up.
I totally agree with the sink button I hit it every time I went to grab the camera when I was setting it up which meant restarting the camera. It was a pain.
I encountered this today and was dismayed. How can any notion of security be expected if cam feed can be wiped out so easily. Are there any options other than making the camera unreachable?
