I just swapped a V2 for a Pan cam on my garage. The Pan was a backyard cam and labeled that way, the V2 was on the garage and labeled that way. I need to switch the names in the app. I’m using a Android. Any help would be great. Thanks in advance…
Select the camera,
Select the gear in the upper right corner,
Select Name,
Select the name and type a new name.
Select Save.
Thank You very much. Have a Great Day
