Can anyone tell me what the strap width is? I want to add a medical alert plate to the strap and need to know the width.
Welcome to the Wyze community!
I would assume you’re talking about the Wyze Band?
The strap length is 9.5 inches.
More information here:
https://wyze.com/wyzeband.html
i WAS ACTUALLY LOOKING FOR THE WIDTH OF THE BAND. CAN YOU STILL HELP?
@learwick23 I measured the strap it is 16 mm wide. I used my digital caliper.
It gets wider where it attaches to the Band (18 mm).
Thank you so much. That really helps.
You’re welcome!
