A squirrel chewed the cable from my V3 camera. The camera has four wires coming out, but the Wyze USB cable has only two conductors. It must only supply power to the camera. Does anyone know how the four wires get connected to the USB cable? I would guess that only two are connected to the power.
Thanks. Foxinsocks
I should have mentioned that the camera’s internal USB wiring doesn’t follow the USB color conventions.
I went ahead and disassembled the V3 and disconnected the USB cable, So a padded envelope with return postage paid would be cheaper than a box with the entire camera.
If you don’t want the free cable I can ohm out the cable later today when I am in my lab and give the color of wires conversion to standard colors so you can splice it.
I will edit this post later and provide colors of wires layout
From the pictures, it looks like the colors on your cable are the same as mine. If you could plug it into USB power and use a voltmeter to check which colored wires have the plus and minus voltage, I would appreciate it. Thanks.
