Good evening
So I am running into an issue . I have the floodlight camera and I am trying to add the spotlight to the additional v3 that’s powered by the back usb port except that the camera will NOT recognize the darn spotlight whatsoever
I used the included cables , made sure to push all of the cables in all the way , i disconnected the camera by unplugging it from the back usb port , I restarted camera , I restarted both the floodlight and the main camera , I flipped the breaker , I turned off the junction box and on , I cleared app cache . But still nothing
The camera just will not recognize the spotlight AT ALL. The spotlight comes on when I connect the cables to the camera initially and then cuts off and doesn’t come back on anymore .
On the v3 live feed I see no pop up telling me to customize the spotlight once it recognizes it , no spotlight icon , going into settings , down to accessories , no spotlight is recognized .
Done everything I can , but I thought this would work as I’ve seen others successfully try this .
Anything else I should do ?
I’ll call support up tomorrow and see if I can get a replacement spotlight then . I bought 5 spotlights kits for my v3’s . 4 of them got installed into stand alone v3’s , and this 5th one seems to be the only defective one from the batch .
I’m guessing it has something to do with it being connected to a back usb port or something idk…
