# Sound issue
**URL:** <https://forums.wyze.com/t/sound-issue/6603>\
**Category:** Cameras\
**Created:** [October 18, 2018, 4:36am UTC](https://forums.wyze.com/t/sound-issue/6603 "2018-10-18T04:36:48Z")\
**Posts on this page:** 11\
**Page:** 1
<div class="post-metadata">
**Author:** ![letsrock16](https://avatars.discourse-cdn.com/v4/letter/l/f08c70/32.png) [@letsrock16](https://forums.wyze.com/u/letsrock16)\
**Post date:** [October 18, 2018, 4:36am UTC](https://forums.wyze.com/t/sound-issue/6603/1 "2018-10-18T04:36:48Z")
</div>
sound is distorted when i let go of mic button
**Post date:** [October 18, 2018, 4:38am UTC](https://forums.wyze.com/t/sound-issue/6603/2 "2018-10-18T04:38:08Z")
</div>
anyone else having a sound issue???
**Author:** ![Loki](https://sea2.discourse-cdn.com/wyze/user_avatar/forums.wyze.com/loki/32/1595_2.png) [@Loki](https://forums.wyze.com/u/Loki)\
**Post date:** [October 18, 2018, 4:53am UTC](https://forums.wyze.com/t/sound-issue/6603/3 "2018-10-18T04:53:26Z")
</div>
How long does it stay distorted. It sounds like you may have a bit of a feedback loop. Is your phone within earshot of the camera when you’re doing this?
**Post date:** [December 20, 2018, 11:18am UTC](https://forums.wyze.com/t/sound-issue/6603/4 "2018-12-20T11:18:11Z")
</div>
It last about 5 seconds but of course the person I’m speaking to has already answered and I could not hear what was said. We’ve tred to count to 5 after I talk but thats a real pain, other than that its crystal clear. i could be 50 miles away with my phone and it does the same…
**Author:** ![OverWatch](https://avatars.discourse-cdn.com/v4/letter/o/3bc359/32.png) [@OverWatch](https://forums.wyze.com/u/OverWatch)\
**Post date:** [December 20, 2018, 12:42pm UTC](https://forums.wyze.com/t/sound-issue/6603/5 "2018-12-20T12:42:34Z")
</div>
When I let go of the speak button, there is a multi second delay before I hear anything. Maybe up to five seconds and sometimes there is a squeak or chirping noise. I haven’t tried to have a conversation, but I can see where this would be an issue.
**Post date:** [December 20, 2018, 11:14am UTC](https://forums.wyze.com/t/sound-issue/6603/6 "2018-12-20T11:14:02Z")
</div>
speaker makes a loud screeching noise after I speak into the mic, on both versions of the camera
**Post date:** [December 20, 2018, 2:26pm UTC](https://forums.wyze.com/t/sound-issue/6603/7 "2018-12-20T14:26:46Z")
</div>
Are you physically close to the camera while doing this? You could be getting feedback. Try moving farther away (where your phone and the camera are not within audio range of each other).
**Post date:** [December 20, 2018, 3:38pm UTC](https://forums.wyze.com/t/sound-issue/6603/9 "2018-12-20T15:38:25Z")
</div>
letsrock16 opened another thread about this same issue. And, I see Matthew cc’d letsrock16. I commented over there that I have heard the same thing or else multi seconds of silence.
**Post date:** [June 12, 2019, 1:45pm UTC](https://forums.wyze.com/t/sound-issue/6603/10 "2019-06-12T13:45:35Z")
</div>
It still does this noise on both of my cams, the small one and the ptz. No matter where I am. I could be at work 50 miles away or in the bedroom and it still makes this noise after I speak into the mic…Has anyone else had this problem or heard of a solution???sorry to keep bringing it up but it is very annoiying… thanks
**Author:** ![Newshound](https://sea2.discourse-cdn.com/wyze/user_avatar/forums.wyze.com/newshound/32/71715_2.png) [@Newshound](https://forums.wyze.com/u/Newshound)\
**Post date:** [June 12, 2019, 4:53pm UTC](https://forums.wyze.com/t/sound-issue/6603/11 "2019-06-12T16:53:09Z")
</div>
There are multiple problems with the sound ATM, but what I think you are speaking of is the electronic subtraction of what you just said over the microphone from the returning sound stream (it is because of this that your voice never gets recorded). I’m guessing they do that to reduce feedback or confusion, but there is also an audio delay that can make it last after you have finished talking. Hopefully this will get cleaned up as part of their sound rework, but the best thing you can do ATM is report all sound issues to the developers:
> [@Audio out of sync](https://forums.wyze.com/t/audio-out-of-sync/6322/36):
> Hello, this is Arthur, TPM from Wyze. I am working on improving audio quality of V2 and Pan Cam. If your device run into any of the following issues: Audio not in sync with Video, in Live View or Recordings Two way communication (Speaking) not clear. Poor audio quality or burst or no sound, in Live View or Recordings Or any other audio related issues Please send the device Mac address and a brief description of the issue to: [hzuo@wyze.com](mailto:hzuo@wyze.com). Mac address could be found under camera settings → …
**Author:** ![DavidKP](https://avatars.discourse-cdn.com/v4/letter/d/f17d59/32.png) [@DavidKP](https://forums.wyze.com/u/DavidKP)\
**Post date:** [April 27, 2020, 8:29pm UTC](https://forums.wyze.com/t/sound-issue/6603/12 "2020-04-27T20:29:44Z")
</div>
Hello Arthur. I purchased a Cam Pan Model WYZECP1 and twice, over a period of a couple days in between, the cam did a loud audio screeching. Both instances were where the cam was idle with little to no activity. The second time, after unplugging and plugging it back in, did not occur for about 3 days. By then I had moved locations and in a quieter area where my dog was. I heard a loud noise like an electric motor with a loud bad bearing going off. Ran upstairs and the cam was all the way to one side facing the wall making the loud noise. I am bringing it downstairs to monitor. Does this sound like something you are familiar with. I have owned it for almost 2 weeks now.
