Sound detection sensitivity too high
I’ve turned the sound detection sensitivity all the way to the lowest value. One. But I still got tons of false alerts. My street isn’t even very noisy. Is this a sensor problem? Is there a workaround? Where is the microphone located? Maybe I can muffle it
This is the diagram from the quick start guide that came with the camera.
If you have lots of sounds from the road way, it may be better to just use motion events for notifications.
