Purchased two Solar Cam Pan2k’s.
They’ve been on my desk for a week, in close proximity to my wireless AP.
They both lose connection to Wireless on the regular, sitting on my desk.
How do I power cycle these camera’s? With my Battery Cam Pro’s, I simply eject the battery, insert the battery. With my WCO’s.. there’s a power switch.
Someone please show me the obvious that I am missing here. How do I power cycle a Solar Cam Pan v2 if it’s not connecting to my Wireless AP?
SJ
From what I can find on the Wyze help pages, the Solar Cam Pan 2K has no power switch or removable battery, so there’s no real power cycle once it’s offline. While it’s online you can use Restart Camera in its settings. Once it drops, the only documented option is a factory reset: remove the microSD card, hold the setup button on top for 20 to 30 seconds until the light flashes red, then set it up again. Since both drop while sitting next to the AP, I’d also check whether your AP uses one SSID for 2.4 and 5 GHz with band steering, because these cams only do 2.4 GHz.
There is something wrong with your AP. These cameras don’t do that naturally. I’ve had these since launch.
I’ve always let me AP handle 2.4 Ghz and 5 Ghz on it’s own, and all of my many other Wyze devices and non Wyze Devices seemed to work OK.
I went ahead and split the two and created a 2nd SSID just for 5 Ghz, and now the two Solar Cam Pan v2’s are working much better.
SJ
