Solar Cam Pan Finger to move live feed
I’m having trouble figuring out how to allow my finger touch on the live feed to move the camera. I know I can go to the waypoint screen and move it with the circle arrows but I want to be able to be in the live feed full screen and move the view with my finger.
On my pan v3 you just hold your finger and drag. Not sure if the solar is different.
I had a v3 and just got the solar. It doesn’t seem to work the same unless I changed a setting on the v3 and don’t remember.
I guess maybe the solar pan doesn’t have that same feature. I don’t believe it is something that can be turned on/off.
Welcome to the Forum, @bzook329! :wave:
I don’t think this feature currently exists for Solar Cam Pan. At least I’m unable to pan or tilt that Cam using any sort of drag or swipe motion. I think the D-pad is the only current control for manual pan/tilt. I’m also not seeing an existing Wishlist request to add this feature, but that’s something you could suggest if you decided to spend more time in the Forum to get to TL1 as described in How to Use the Wishlist.
