Yup, still having issues. I have given up going thru the processes over and over different ways with no result and I’m not trying to deal with service. I tried initially and it was just ai crap. And I don’t have the time to play with it anymore. It’s working at the wall unit at least for time being and I’m looking into switching us off wyze cuz this would be totally unacceptable in another couple months in Pennsylvania. Unacceptable
Direct me in regards to filing against wyze. I’ll jump on that.. This is unacceptable
I do understand your frustrations. If you do want to give support another try, this number will avoid the AI.
206-339-9646
New app version released on 10/12/26, version 3.23.2.1001 for Android. Who’s on that version and still having thermostat issues? I still have not updated from original hot fix version 3.22.1.979 as it had returned my thermostat to working like before all of this nonsense happened. My thermostat since factory resetting it during that still does not report time to target temp countdown correctly. States 1 minute for each degree of difference… How on earth could Wyze botch an app update so badly and poorly?
What really grinds my gears is that they won’t say the product is completely dead – the store only has them as sold out, same with the refurbs. If I have n issue, I’d love to stay in the Wyze ecosystem, but the way they abandon products, they’re almost as rough as Google is on home devices.
I think the Wyze thermostat isn’t generating enough revenue for the company to care. Unfortunately, it’s one of those products that most households buy once and won’t replace for years. Sadly, it’s all about money.
They could always come out with an updated version. Maybe a more intuitive display or refreshed design. Google does that with the Best and if I recall, Ecobee is on their 5th generation. Wyze refreshes their cams and doorbells, why not the thermostat?
Still no thermostat thru the app. What a bunch of garbage
On the latest app version?
Still not functional via app.
For us, Now it’s stuck in setup of tstat in the app and telling me to disconnect 2 of the only 4 wires connected in the system because they aren’t correct… None of that has been touched since date of install. So nothing has changed since before or after their update they did physically on my end, and the tstat still functions and is working hot/cold/auto via the wall unit, Their rubbish app is the culprit still.
It’s ridiculous.
Looking into changing systems because it’s starting to get colder in the NE USA and if that thing goes down fully again(from one of their “updates”) in dead of winter… There will be blood.
They seem to think their little “hotfix” was all that was necessary. It wasn’t! I used to like our cam and tstat setup with wyze, but I’m pretty much done with them after this.
Mines still stuck in setup via app telling me to disconnect 2 of the only 4 wires cuz they’re incorrect… Nothing was ever changed, so that’s bologna and the tstat and HVAC are functional just fine via wall unit. Fix the damn app already. Tech support will not amend this.
I recently ran Factory Reset/Setup and was able to re-install the Thermostat using Wyze App v3.23.1.994.
I have 5 wires that I labelled G, W1, Rc, Y1 and C during the original install.
I just entered these into the App during re-install and it connected.
What are the labels on your 4 wires?
Can you contact the support team and then give me your ticket number so we can get this resolved? From what I am seeing the hotfix has pretty much fixed the issue so yours must not be related to the app issue that the hotfix addressed. The support team will need to collect information to look into this further.
Wyze Support
206-339-9646
Same here dropping wyze one device at a time as they fail. The thermostat has been solid since day 1 now cannot connect to my app.
Which app version are you running?
