Smart Thermostat Offline
Jo53ph - I was able to re-add my thermostat using an old android tablet. Android updates keep breaking the thermostat. What I’ve learned is: don’t reset the thermostat when Android breaks it. Use the manual controls until Wyze App catches up with the Android changes.
Thanks @LottaWdevices Unfortunately in this situation it’s too little too late. Wish Wyze got ahead of these problems and had better QA so this wouldn’t happen. At the very least they could send out a notification or alert saying don’t attempt to factory reset? Especially with known android update schedules… SMDH
We did find it extended past Android 17 into other versions.
We have found the root cause and are working on the fix. We hope to have it out soon. I will keep everyone updated.
You can get the thermostat back if you have another phone not running Android 17 (or16?) or borrow from a friend. I had the same issue and was able to add it using an older MotoZ phone running Android 9. Once added, I can use the MotoZ or control manually. Hopefully Wyze can get it resolved soon.
I am on update 37 Android 16 as of yesterday on my S24+ and this is my problem too. My wifes still is showing online. How does this happen, hers is a S24 and on the same update.
You may be on different versions of the Wyze app.
Can you explain how your able to use Alexa if the Wyze Thermostat shows offline on app? TIA
One idea is to have the opportunity to downgrade the Wyze App to an earlier version, I mean a working version. Just saying. Thank you
You should still be able to add the wyze skill through alexa. There’s a bug with the wyze app telling you it’s offline but actually isn’t. So the Alexa/Google app is still able to pull the data. Been using it today and yesterday and it’s been fine. Telling Alexa to change the temp is also still working.
Also have a pixel 9a, Android 17. Cameras work fine but thermostat shows off line in the app but my router shows it connected with a good signal as does the Wyze Thermostat itself.
Thanks, I got it working as an alternative.
Never resetting thermostat again. Showing it offline is inconvenient but not being able to use the thermostat at all is infinitely worse.
Exactly the same situation
This is outrageous. I followed all the steps to reconnect my thermostat and now I cant control my AC in Phoenix AZ of all HOT places. It says to factory reset and now I’m getting a hotel room. Where is the official statement from WYZE? Why is this not in the news? This is so irresponsible of a company to keep quiet and fix in the background just to save face. Do Right by your consumers! WYZE owes my hotel room fees until my AC works again.
Resetting itself isn’t the problem, it’s that the app has a bug. Not sure the issue, not sure Wyze will even disclose the issue, but they clearly aren’t testing releases before deployment, especially if initially over a week ago this happened, they fixed it and it’s happening again?
In your case, you need to get another phone or tablet running an earlier Android version or an iPhone or iPad to re-setup your thermostat. That’s exactly what I did to get mine back when I initially reset it when this all began.
If wyze was truly customer centered, they’d be sending out emails and/or text messages IMMEDIATELY to advise people to avoid resetting their thermostat until a verified working fix was available. Guaranteed they are losing customers over this, especially if it’s happening twice within a two week period. I might add that the southwest, particularly AZ and So Cal are experiencing NWS issued extreme heat advisories for the next week through 10/8 of 100°+ temps, so Wyze is hopefully working overtime for a fix, at least they should be at this point.
Glad I keep checking back here in this thread even though mine is still good so far, but probably because I’m still on app version 3.22.1.979 which it sounds like there’s a version 3.23 since the original fix which is the version I’m on, and I haven’t ran or even checked for an Android update so far this month.
My thermostat is stuck on the wyze logo screen. I understand it needs to be replaced. How do I do that? If I cant get it replaced and have to go to another brand, that will include 15 cameras, scale and a service monitoring plan.
Mine is doing the same thing.it kept saying offline,so I went to delete and reinstall it,and I can’t even delete it from the app to reinstall it.
Another reason I am slowly getting rid of Wyze stuff. 5 cameras in the trash and 5 to go. Looking for a new thermostat and smart plugs. I am done with always having a issue with one thing or another. The sd card issue is what was the final straw.
I bet it’s in reset mode. Unless you’re on a older version of the app or OS for your phone or can find one to install an older version you’re SOL is my understanding :melting_face:
Said multiple other times in this forum thread but you could fix it by using an older OS version of iOS or Android I think with an wyze app installed to temporarily use to setup the thermostat. Still won’t fix that it’s showing offline in your new OS version phone though unfortunately. They’ve been working on this for days now apparently. :man_shrugging:t2:
