Sleep Routine stopped working
My Sleep Routine stopped working. I had it set up for 5:30am and now it does not turn on. I tried automation to turn on 1 minute before the sleep routine at 1% brightness, it does turn on but sleep routine still does not activate. I deleted the Wyze Color bulb and installed it again with no success. What could be the problem? I even tried with another Wyze Color bulb and it does not work either.
Same issue, power cycling also changed nothing
We are having the same issue for the last couple of days or so. All the bulb firmware up to date and no changes with the settings so it feels like an issue at the Wyze end.
so on the automations Page just to the right of where it says my automations, There is a wrench icon, Click that as it will search for any automations that have any issues. Run that and see if it gives you any further insight as to why it’s not working. And keep us updated! This was implemented a while ago. I mean, quite a while ago actually, and I still forget to run it every now and then when I’m having issues. And having as many devices as I do. And changing them or removing them from a group, or numerous other little things you might do and not realize it has impact. This usually finds them.
Same thing here. It just randomly stopped working within the last few days. I see there was an app update ~3 days ago according to the App Store. Probably related? Hopefully this is resolved soon.
I did try power cycling and other bulbs. No luck.
Same issue here, as of a few days ago. I made no changes to anything before this started failing. This is the primary reason I have these bulbs and now it is not working.
First, I don’t see any wrench icon on my automations page, just a little house that when clicked shows Automation History.
Second, the issue is not with Automations, they work fine. It is with the Sleep Routine that is located within the Color Bulb settings.
Thanks.
Same issue with four lights. The sleep routines stopped working a couple days ago. I tried factory reset, deleting and readding in wyze app, turning off for 30+ seconds and back on. No dice. Hoping this get’s fixed soon, failing sleep routines is very disruptive to our sleep routine.
Same here. Sleep routine exists but hasn’t worked for several days. I miss it!!
I’ve been having the same issue for the past few days, too. All of my automations are working as expected, but the Sleep Routines (set up in the bulb settings section, separate from the automations) aren’t running in the morning or at night.
I tried all of the troubleshooting suggestions from the app chat bot, plus some others mentioned on forums: firmware updates, changing the start times to not end in 0, power cycling the bulb and my router, uninstalling/reinstalling the app and the bulb, checking my router settings, etc. Nothing worked.
Seems like this is a Wyze problem, so I hope they correct it soon.
This morning my bedroom lights worked, but for some reason it turned on my living room lights as well even though they should be on a different schedule for my pets. At least a fix may be in the works
It looks like they fixed it. Hopefully it won’t happen again
Agreed, appears to be fixed. Yay!
My apologies, I miss understood, that one I’m not too familiar with is I haven’t used mine, I haven’t felt the need. But it’s looking like some people are seeing it reported good.
Mine has been messed up for months and just gave up on it. Thanks for bringing it up!
