Size of detected objects
Is there a way to set the size of a detected object.
I want to stop my cameras from recording the movement of insects
Nope.
If the v2 supports person detection or other choices then that would probably be the best you can do. If you’re using b&w night settings or something though that can make it worse.
There’s not really anything else besides silly odds and ends so I don’t really want to list anything else.
Objects may be smaller than they actually appear.
