Simple Question Re Pan Cam V3
Where is the “home” position?
With the speaker facing away from the bracket or facing at it?
Thanks!
Neither.
The Home position is where you set it.
With Scan and Detection Zone Off, it is the last place you manually left the cam FOV.
With Scan Off and Detection Zone On, it is the FOV of the DZ when it is saved.
With Scan On, it is your waypoint(s).
When mounted, the power cord should be routed to the back of the cam toward the center of the mount. That point is the rotation stop position. The cam should rotate nearly 360° from the back, where the power cord exits, all the way around to the power cord on the other side.
That’s what I’m looking for.
It’s how I have it set up.
Thanks, SlabSlayer!
