I have 2 x V4 cams which are now forever either showing as “offline” when trying to live view or “failed to connect” 9 times out of ten only a hard power cycle will fix the problem for a little while before it shortly all goes t*ts up again with the same errors. Both are set up with Secure RTSP as I wanted to avoid the yearly charges. I relented after buying another V4 but I had reached to limit for connection to my NAS Surveillance Station.
Now having a think about it, I am going to remove the RTSP and see how things go with just the app. wish me luck
You have the beta test icon, and another user has reported the same issue with the latest beta. That’s to be expected with beta firmware, you should report this in the beta thread/forum.
I have reverted to the release FW and removed RTSPS from the installed V4’s, over 24 hours now of no dropouts, freezes or offlines. I have also set up a spare V4 running release FW with RTSPS to test, also running release FW. I intend to monitor for a few days before upgrading this camera to beta FW
