Siamese cord
I suggest offering a short siamese cord which has 1 female mini usb and 2 male usb ends. This would allow you to run one power cord and be able to power 2 cameras that are close together. I have mentioned this to several Wyze people who thought it was a good idea but 2 years later it is still not available.
I’ve bought some splitters on Amazon that do this for around $7:
Works out great to point 2 cams in opposite directions for better coverage. Though I purposely use a different adapter that allows more power to be sent through since I’m running 2 cams on the same cord.
I wouldn’t do this with the V3Pro cams as they need more power than normal, so it’s kind of best for them to have their separate cord and power source.
What is the amperage draw on the V3 pro?
I haven’t personally tested the draw, but the website says they provide an adapter for it that gives 5V / 2000mA for the V3Pro
While the V3 says 5V / 1A.
I just discovered that there is a siamese cord supplied with the spotlight kit for the V2. I’ll let you know how it works using a std power adapter.
