I use new SAMSUNG / SANDISK Endurance 256 GB microSD card, in exFAT, with a new WYZE Battery Cam Pro. Recording to microSD card stopped after 2 whole days and has more than half its capacity untouched. I found this out when I arbitrarily pulled out microSD card on day 5 to review footage. Also there seems to be numerous and random lens shuttering sounds during that time which Idk if its normal.
Related topics
Topic | Replies | Views | Activity | |
Recording stopped ?! | 17 | 155 | April 22, 2025 | |
Wyze Cam OGs are killing my SD cards | 49 | 568 | May 14, 2025 | |
Micro SD card works fine for a few months, then stops saving and erases files and shows error code on my PC | 1 | 718 | May 4, 2019 | |
What SD Card Are You Using For 24/7 Recording? | 15 | 3549 | July 3, 2024 | |
Battery Cam Pro SD Local Storage | 3 | 623 | November 26, 2023 |
