Shortcuts and Rules with multiple if/and/or conditional triggers
This is exactly what we need so bad and I don’t understand why it would be so difficult to deliver, it’s just more of the same.
I agree this is really the crux of this thread because today we already have multiple actions but so much power with no real ability to control it (multiple conditions) goes completely against Uncle Ben’s wisdom (not very Wyze).
I need the ability to trigger from multiple device conditions. If the door #1 is open AND door #2 is closed but there is no motion in room then lock door #1 (and perhaps only within certain time range). Smarter rules for the smartest devices. If Wyze can deliver they will begin to demonstrate a major distinction in their ecosystem.
I just spent the better part of the evening recreating the exact same multi-action rule for 16 different trigger cams. :angry:
By the end, I was going cross eyed trying to make sure I got them all the same.
This could have been accomplished with 1 rule and 16 “OR” triggers, not 16 seperate rules all with identical actions.
Allow AND in rules
Please allow the ability to have multiple device triggers for an action. IF the temperature is blow 65 degrees AND motion is detected DO turn on plug IF time is between 7am-4pm.
[Mod Edit] Merged with an existing wishlist topic. Give it a vote to help it along!
OR-IF ORIF functionality
In the rule creation process, we really need OR-IF functionality where IF one of several events occurs, a desired action will take place.
For example: IF a person is detected on CAM1, or CAM2, or CAM3, or CAM4, or CAM5, TURN ON floodlight. Right now I have to write 5 individual rules
IF CAMERA 1 PERSON DETECTED - Turn on flood light
IF CAMERA 2 PERSON DETECTED - Turn on flood light
IF CAMERA 3 PERSON DETECTED - Turn on flood light
IF CAMERA 4 PERSON DETECTED - Turn on flood light
IF CAMERA 5 PERSON DETECTED - Turn on flood light
Additionally, WYZE seems to be a little flaky with timing. I can’t say between 9pm-5am because it doesn’t work. I have to say between 9pm-1159pm then add another rule that says between 1200am-500am
The total rules for night time monitoring of 5 cameras becomes this:
IF CAMERA 1 PERSON DETECTED - Turn on flood light - between 9pm and 1159pm
IF CAMERA 1 PERSON DETECTED - Turn on flood light - between 1200am and 500am
IF CAMERA 2 PERSON DETECTED - Turn on flood light - between 9pm and 1159pm
IF CAMERA 2 PERSON DETECTED - Turn on flood light - between 1200am and 500am
IF CAMERA 3 PERSON DETECTED - Turn on flood light - between 9pm and 1159pm
IF CAMERA 3 PERSON DETECTED - Turn on flood light - between 1200am and 500am
IF CAMERA 4 PERSON DETECTED - Turn on flood light - between 9pm and 1159pm
IF CAMERA 4 PERSON DETECTED - Turn on flood light - between 1200am and 500am
IF CAMERA 5 PERSON DETECTED - Turn on flood light - between 9pm and 1159pm
IF CAMERA 5 PERSON DETECTED - Turn on flood light - between 1200am and 500am
Now unless I am missing something, OR-IF logic capability in the rules could reduce this all down to 1 rule.
Need to add multi triggers with “AND” and “OR”. I’d like to turn on a vent fan when the inside temperature is higher than the outside temperature. This would also require the ability to reference a sensor’s value in the trigger.
[Mod Note]: Post relocated to correct wishlist topic.
