Sharing the outdoor camera with husband but he is not getting notifications.
Any advice?
Welcome to the community @n.aurnhammer
First, are you getting notifications. If you are then your husband may have inadvertently turned notifications off. This can be accomplished via 2 ways:
Go to the app and on the main home screen in the top right you will see a bell (notifications). Does it have zzz across it. If it does, notifications are off.
In iOS Settings, does he have notifications turned on for the Wyze App?
Thanks
Thank you! I checked everywhere except the iOS setting…you’re brilliant!!
Glad you found it. I am sure you would have eventually.
