Android 8 and WhatsApp v2.19.330
Just for completeness sake I added the app to my phone and my wifeâs (sssshhhhh donât tell on me) and sent a 21 second CMC event video from my phone to hers via WhatsApp.
I downloaded the event video as normal to the photos app, then sent the video as normal via WhatsApp. The file was 7 FPS and about 1.8 megs.
Both phones were running the iOS flavor of the week 13.2.3 and both were running Wyze app version 2.6.62 and both were running WhatsApp version 2.19.112. The audio was not playable however just the video.
CMC clips are downloaded without an audio track, correct? So if the audio codec is the problem here I would expect those to transfer without issue. So might a standard cam clip on a cam that is set not to record audio.
Can you transfer a 12-second event clip that has an audio track?
So far the problem has been reported on some Android phones, but this iOS test is useful too.
Thanks!
Let me give it a whirl, hang on.
UPDATE: Sent a 10 second (was meant to be 12) clip with audio to my wife. It did indeed send AND it retained the audio track and played just fine on her phone.
Thanks â it is using the ALAW codec like we suspected.
Now if we could just figure out what is different between @wah.jai99 who canât send, and @StopICU33 who can.
The issue I find with Android is each manufacturer can and does mess with what Apps and Settings are standard for them. Unlike Apple there is no such thing as a standard messaging app for SMS or MMS etc. Android has just introduced RCS messaging which may in fact become a standard. The same is even more true with codecs and AV file format and support. The first thing I generally do on an Android device (and for that matter on a Mac or iPhone) is install VLC because then I get a consistent experience on every platform.
Are you by chance using any type of antivirus software?
Yeah thatâs oddâŚI updated to WhatsApp v2.19.341 but it still works with no audio.
No antivirus software installed.
I was once again told by support that WhatsApp is not supported. Iâm confused and frankly, I give up.
Can you give us your ticket number? I would like to see if I can get someone from Wyze to look at this.
Ticket number is 382262.
Hey, folks!
This isnât the first time that WhatsApp has come up. From what I understand, our files donât play well with their platform. So I guess itâs technically an issue of WhatsApp not being supported but not in an intentional way.
You may want to contact WhatsApp for support. Have them explain why they wonât accept a Wyze video clip. Maybe youâll get lucky and find itâs just a setting. After all, some people with your version are successful.
The team is going to look into this (I asked the product team about it). We made changes at one point so that it would work with WhatsApp so we want to look into why itâs working for some people but not others. Thanks for bringing this up!
Well the person it works for stated he saved the video to his phoneâs video library and shared it from that location. He isnât sharing from within the Wyze app.
That is a big difference in methodology.
Yeah, but
Saving Event clips locally to my gallery result in the same error when I try to send via WhatsApp.
This has to be an issue only with Android. From the event video on iOS I can hit the share button and then select WhatsApp and away it goes. No issues, and I donât have to save it locally first. But I can save the video or pick an already saved video and send that with no issues as well.
The way I share the video is, I go to my Wyze app album, click on the video, click on the share icon at the bottom. Then send it to WhatsApp. Works every time for me.
