I have a WCv3 with a WC Light Socket attached.
I have a rule to turn on the socket when the v3 detects a person or a vehicle.
The rule runs fine, the light in the socket turns on.
But it never turns off.
I do not see any way to turn the light off after say, 10 minutes. I read that the rule should revert to off after the motion detection goes off, but that does not happen.
There is an ability to turn off the Socket light after x minutes in the accessory settings, but that is for simple motion only.
Unfortunately, the ability to ‘turn off after x minutes’ from a Rule still eludes V3 light accessories. However, there is a workaround if you have an unused Plug lying around.
You basically use the Plug as a memory device:
Make a Rule that says if the V3 sees a person, turn on the Socket light AND turn on the Plug.
Make a second Rule that says if the Plug has been on for 10 minutes, turn off the Plug AND turn off the Socket light.
Only glitch with this ATM is 2021 CFH Plugs (Bluetooth setup) currently have a glitch where they won’t stay on line reliably. This will hopefully be fixed soon. The workaround for that appears to be to touch the power switch twice? Or maybe you have an older Plug available?
Just wondering if this is/has been worked on by Wyze, as this really is the reason most people buy the socket, I’m afraid to buy the flood light because it probably works same way, no way in rules to turn off after x minutes on.
Still nothing here, I just buy two of them and waiting for this specific feature, is not very complicated to add, it already exist on the other devises.
With the latest IOS app update there is now a device trigger action that allows you to set the socket to come on for X minutes, it’s at the bottom of the action list at least on my iPhone, just set it up for my camera v3 and will test tonight to turn on socket after person detection on different V3 camera than one attached to the socket
