Setting up thermostat after reset
I have been having trouble with a thermostat not reconnecting to my wifi after losing power. One of the suggestions is to do a factory reset. I have done that, but when I go to set it up again through the app, it wants me to input the original wiring setup. I did this originally a year ago, so I have no idea. How can I answer the questions based on the current wiring? Thanks in advance.
When you get to the question asking you to put in the wires , if you don’t know your wiring off the top of your head I’d suggest going up the device and remove the t-stat from the wall panel and you’ll see the wiring and you just put in the wiring to the app
