Hi Everyone. Can anyone help please as I do not want to mess up settings!
What do I want to achieve- Have 1 camera out of the 4 installed that I want to be able to send notifications whilst the other 3 are in a schedule to turn notifications on and off at specific times. So in other words have the one able to send notifications 24/7 should it be triggered. I have looked at the settings but to be honest it’s doing my head in trying to find the correct and easiest way! Must be the NZ heat at the moment!!! Thanks for any help given, much appreciated.
Using an automation is the easiest way to do that, I do that exact thing. You would create a single automation for the 3 cams and tell it what time to turn the notifications off and on. Well you could do 3 different automations if you wanted the times to be different.
The 4th cam you just have them and leave them on, nothing needed there.
