I like using the pan function but I have them on the window sill and after it pans around a while tends to walk itself off the window sill and crash to the ground. I know there is a mount but that seems like over kill for this.
The rubbery bottom doesn’t seem doesn’t stick to tape well I found.
I’ve used double-sided carpet tape, Velcro and for more permanent installations, 3M adhesive patches(like the ones that come with the V2) All available on Amazon.
I tend to move mine around so trying to not stick something to paint. Trying three rubber feet like on the bottom of a cutting board and see if that does it.
