MFP hired this critter to keep guard of the water while he is taking a nap again.
That is one good-looking and healthy-looking squirrel
Why don’t the last 3 seconds play in the video. Because now it has a banner that says Captured by WYZE Cam V4 at the end.
I have a yard full off those Red Tree Rats.
Can you elaborate? Is this (it not playing the last few seconds of the event video) happening in the app as well, or just on the downloaded video? Did you remove the captured by Wyze clip at the end? Can you give more details? It may be something I want to pass on to Jason.
It only happens with downloaded cloud event videos on all cams. If I play the video on VLC it just shows up as a quick flash unless I go frame by frame then I get this: If I go frame by frame on other video players it just shows up a a big white flash.
I downloaded 3 cloud event videos from 3 different types of cameras to my Android phone. The cameras are a V2 WCO, a V3 Pan and a WBC Pro.
I am running the Android app version 3.2.2.586. I do not see that splash screen at the end of any of the videos. I have not yet loaded them on my laptop to view them in a different viewer.
It shows up on VLC and also on my YouTube videos, the last 3 seconds.
I noticed it is showing up for me now too on a Cam Plus Video I just downloaded last night from my Floodlight Pro:
I am not a fan of this being forced without an option. IMO there is a case to make to do this for recorded videos from the SD card playback, but not really for Cam Plus videos. I usually pay a subscription to get RID of watermarks, etc from documents, videos, and pictures, not pay a subscription to have them added to my files. You may add it to the metadata if you want, but you shouldn’t edit or visually alter my actual video. At least that is how I have always expected subscriptions to work.
Already doing free advertising for WYZE since my cams have the WYZE logo turned on. I’m going to turn it off for the night as per orders from MFP who just came by a few minutes ago.
