The setting for my SD card keeps turning to from on to off, I can turn it on, go back later and its off again??
Card has been formatted, is the recommended 32gb card and set to record events only. Thoughts??
Even when the app says it’s off, does the camera still record?
Are any other cameras doing this?
If the camera isn’t recording when it switches to off, try deleting the camera and adding back to the Wyze app.
Are you waiting for your camera to connect to a live view before going into it’s settings? If you access the settings menu it may not populate correctly if you have actually connected to the camera yet.
