Hi do you use outdoor wyze?
Rick
Rick
Yes ⦠v3. I should have specified in the original post.
I want to add that after doing some testing (trial and error mostly), I realized that after formating a 128GB micro sd and inserting them into the V3 Cam, outdoor cam and itās bridge., unlike the V2 cameras that will make a sound when a card is inserted and almost immediately be visible in the app that a card is in the device, these newer cams not only donāt make a sound when a card is inserted but also the app does take a good couple of minutes to recognize the card.
Now, this did not always happen but when it didnāt come up right away and waiting a couple of minutes the devices do recognize it. Donāt forget that it needs to be FAT32 format.
You did goodā¦I have one v3ā¦the rest are wyze outdoor . I just tried to do a schedule a recording in lower garageā¦
And it said again no sd card detectedā¦yesterday all was goodā¦puzzling sometime for meā¦
Thanks
I had this issue a couple times and it always fixes itself if I take it out and put them back in right away or change the sequence putting it in right after turning on camera or just before restarting.
Hey thanks I will try thisā¦appreciate fast reply
Rick
