How does the camera save the videos on an SD card. Most importantly, can you pull the card and view them on a computer?
Yes, you can pull the card and view them on a computer.
Should the SD card be formatted in FAT or NTFS?
FAT32 is the supported format
If you use VLC free video player you can fast scan through the videos on your Mac or PC by increasing the playback speed. Saves a lot of time on video review.
Hope this helps,
Thanx,
73’
Tuna
