Subject: SD Card Playback Timeline Shows ~30-Minute Offset from Actual Camera Timestamp
Dear Wyze Support Team,
I am experiencing a time synchronization issue specifically with SD card playback on my Wyze camera.
I have verified that the camera’s actual time is correct. During Live View, the timestamp shown on the camera matches my mobile/computer time exactly. For example, the attached screenshot shows:
Device time: 09:35 AM
Camera timestamp: 09:35:10 AM
Therefore, the camera clock is correctly synchronized.
However, when I play the same recording from the SD Card in the Wyze app, there is an approximately 30-minute discrepancy between the actual timestamp embedded in the video and the SD-card playback timeline.
For example, in the attached screenshot:
Actual timestamp displayed inside the recorded video: 07:10:09 AM
SD Card playback timeline/cursor: approximately 06:40:11 AM
Difference: approximately 30 minutes
This indicates that the camera clock itself is not the problem. The discrepancy appears to be with the SD-card recording index/playback timeline in the Wyze app.
Could you please investigate whether this is a known issue with the current Wyze app/firmware or SD-card playback system?
I would appreciate guidance on how to correct the SD-card timeline without losing my existing recordings.
I have attached screenshots showing both the correctly synchronized Live View time and the approximately 30-minute SD-card playback discrepancy.
Thank you.
