SD card not recognized and now Camplus isn't either
In November, all my pancams SD card says “no video available at this time” and now today, they all show I have the camplus (even went onto the computer to double check invoicing) and none of them will show camplus events. Instead, when I try to filter, it says I don’t have a subscription.
What the heck is going on? How do I fix these problems? I see others posting about the SD card issue, but help is being mute and saying nothing or addressing it. So, I assume the same will be true with recognizing there’s a problem with a paid service not being recognized.
Which Wyze app version are you running?
hi Seapup - Android Version 3.8.7.725
There was an outage 2 hours ago that appears to have affected services. That was fixed about 5-10 minutes ago. Try killing your Wyze app and restarting.
Thank you! I will try that!
