Since the last update, I am unable to view live stream on some of my cams; I get “No micro SD card” error message. I am also getting “error code 20011” on one of my cams.
Check if there is anything wrong with the memory card . Turn off the camera, and remove and insert the memory card several times. Then, turn on the camera to check if the issue is resolved. If you have more than one memory card , check if another card is recognized correctly.
This has been seen and reported in Beta v2.4.93. Hopefully they are working on it.
I have done everything you suggested, unfortunately it did not fix the issue. The problem is only with my my 2 smaller cams.
Check that your Wyze 2 was affect by the R65 production line. You may eligible for the replacement.
