Scale Ultra BodyScan - MAJOR FLAW IN WYZE APP
Context:
I bought the Scale Ultra BodyScan to track changes in muscle/ fat in specific parts of my body over time. For instance, I wanted to see if I’m gaining muscle in my arms over time as I lift weights.
Problem w/ the Wyze app:
The app only shows me a single day snapshot of each bodypart with no trends/ changes over time (the current trend feature in the app only shows at total body muscle/ fat mass .. which is what the other Wyze scales already do). The only current way for me to see progress at the body part level is by screenshotting my results each day and manually comparing myself … which is a massive pain.
Solution:
Without an update to the app to visualize body part trends, there is effectively no reason to trade up to the Scale Ultra BodyScan from other Wyze scales, or to choose it over similar body scan scale products offered by competitors. The good news is Wyze already has the body part data … you just need to add a body part trend feature to the existing app which should be a simple fix. PLEASE ADD THIS. The premium charged for the BodyScan feature is essentially not worth it without a way to track progress.
