Rules with Actions
Is there a way to create a rule/action that reverses the current state of the device? Action change the current state of the device, for example, if light off, turn on, Then same action, if light on, turn off? Without having to write two different rules, one for on and one for off?
At this point in time, No. I do know that this is something which has been requested and Wyze is looking into the best way to do it. But currently, there isn’t a Rule or Action to do this.
You don’t need two rules – just create a scheduled rule. First, you set a start and a stop time. If action is turn ON the device, then start time will be turn on, and stop time will be turn off. If action is turn OFF the device, then start time will be turn off, and stop time will be turn on.
