RTSP PAN cam update spinning base makes it impossible
Hi Trying to update to rtsp on the pan cam and the base spins over the setup button making it impossible to complete the process without grinding the drive gears - bad design in hindsight
can you share your secrets hot you got it done thanks I dont want to brick my cam
