RTSP Explanation Please
RTSP? Can someone please explain this? Thanks in advance!
RTSP is a type of streaming protocol that allows a smart camera to stream live video and audio directly over a local area network (LAN) or the internet.
If you want some examples of what some of us want it for and would like to use it for, you can see my post in this thread where I explain to Wyze why I wanted them to support it:
In plain terms, RTSP gives the camera a local stream address, a URL like rtsp://user:password@camera-ip/live, that other software on your home network can open directly without going through the Wyze app or cloud. People use it to watch the camera in VLC, record to a NAS like Synology, or pull it into Home Assistant or Blue Iris. Support depends on the model and firmware: on cams that have it, it shows up under the camera’s Advanced Settings, where you set a username and password and it gives you the URL. If you tell us which camera you have, someone can say whether it is available for that one.
They tagged this thread as the v4 camera (which does support rtsp now, at least in beta), so I think OP likely saw RTSP in the advanced settings for their v4 camera and wondered what it was.
RTSP isn’t something everyone will use or care about, but it something lots of us have begged for over the years, and they finally started adding it. :heart:
I do have the v4 plus an OG and some v3 and v2’s, 23 cameras in all. I also pay $100 a year to be able to pull up the video feeds on an ipad, an Amazon HD 10 or computer. But the problem is the video takes a long time to show up and then it quickly goes into a “Web Connection Failed” mode. Plus I can only watch 8 and sometimes 9 cameras at a time. Would the RTSP solve these problems? Is there a tutorial on how best to accomplish this feat?
RTSP is usually VERY fast because it is all local :+1:
This should happen much less often if at all.
That’s assuming the issues aren’t partially being caused by your router, etc. Sometimes default ISP routers don’t work well with lots of devices or heavy live streaming of multiple devices. So I can’t promise that isn’t part of your problem.
I will say that I have been able to watch over 2 dozen live streams on my computer all at once with no problem using my Ubiquity Unifi Network.
Pretty good chance, yes.
The following were the original instructions for setting up RTSP back when it was in Beta. They may not all apply now though:
https://wyze-beta.s3.us-west-2.amazonaws.com/rtsp.html
Then you’ll want to run some searches for a program that you copy the RTSP stream link into and those programs will then let you customize the view how you want. Some are free, some are paid programs. I haven’t used a lot so I hesitate to recommend which you should get. I mostly use RTSP in Home Assistant. I also use it to save some video to a local harddrive for key priority cameras.
Would RTSP allow Windows to treat the SD card as a USB drive, like it does when inserted into a PC or reader?
And that would be after some sort of stop recording to SD card and Eject sequence that removes it from the Wyze app, so that Windows wouldn’t think the card is already in use by a program.
That would allow running some Windows operations on the card without having to remove it and take it to a PC for working on, and then bringing it back to the camera.
Is this possible?
No. Though actually year ago in the past there was a way to do this, to access the data on your Wyze cams as long as your computer was on the same secure WiFi network as the camera (and only from a device that already had approved access to the secure WiFi network already, not remote access)…but people spazzed out and called it a vulnerability. :-1: So Wyze blocked it and it’s no longer possible and they’re unlikely to provide support for this after all the overly dramatic reaction that came from it being possible in the past. So even though this is one of the biggest all-time most popular wishlist requests…assume this will never be allowed again. Thanks a lot dramatic people…lots of us have been wanting that capability ON PURPOSE for years. :sob:
yancx, one thing that helps a lot when you watch many cameras on one screen: if your cameras let you pick a lower resolution, set that for the wall view and only open a full size feed when you click on one camera. Nine or ten full HD streams at once is heavy for a normal PC, even when everything is local. Also use a cable to the PC if you can, wifi on the viewing side is a common reason for stutter. For the viewer, VLC is fine for 2 or 3 cameras but gets painful at 9, so look for something built for multi camera grids (go2rtc or a small NVR program both work with RTSP urls). How many cameras are you trying to show, and what PC is it? That would decide what will run smoothly.
