What happened to the Rotate Image Toggle? It isn’t an option on any of my cameras. It used to be under the advanced settings and I don’t see it in an of the settings menus. Was it moved or removed completely?
Might be a change for the Battery Cam Pro since I still see Rotate Image for my Cam v3.
AFAIK, this has never been an option for Battery Cam Pro, and it’s been mentioned several times elsewhere in the Forum.
BCP isn’t meant to be mounted upside down, my guess is due to water infiltration into the battery compartment. So that option isn’t available for it.
