Robot-Vacuum Update
Model: WRV200S
Firmware: 1.6.306
Plugin Ver: 2.36.1
Wyze App Ver: v2.38.0 (153)
Battery is 2 years 4 months old
I have found that allowing batteries to drain below 50% will cause some damage to the battery life! I have set it up to allow a schedule for 2 rooms at a time and it returns to charge for 30 minutes and then 2 more. It seems to be good for me.
Vac returns at 60% to 65% of charge. I’ve added a room but brings it back at 45% left in battery life.
Hope this helps!
UPDATE: Year 3 on my 2 vacuum systems and battery life all original software and batteries. No problems to report and all functions are working properly.
I have not updated any software/firmware as listed below:
Model: WRV200S
Firmware: 1.6.306
Plugin Ver: 2.36.1
Recommendations: Clean the unit thoroughly, don’t just wipe the surfaces that don’t really clean properly by using the Q-tips/moistened works for me. Also purchased a portable BLOWER F3I CCV 5vdc rechargeable is the best to remove any moisture/dust from the unit/filters/Ladar…etc.
Docking base adjuster for unit with any carpets - - Purchased Metal only! double wall switch plate to put down if front of dock stations works great and causes vac to align properly for charging. Hope this helps you in your future.
Regards Capt.Rob
