# Robot vacuum mapping? Moving the charger?
**URL:** <https://forums.wyze.com/t/robot-vacuum-mapping-moving-the-charger/234053>\
**Category:** Home\
**Tags:** robot-vacuum, support\
**Created:** [June 27, 2022, 2:34am UTC](https://forums.wyze.com/t/robot-vacuum-mapping-moving-the-charger/234053 "2022-06-27T02:34:30Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![srice](https://avatars.discourse-cdn.com/v4/letter/s/d9b06d/32.png) [@srice](https://forums.wyze.com/u/srice)\
**Post date:** [June 27, 2022, 2:34am UTC](https://forums.wyze.com/t/robot-vacuum-mapping-moving-the-charger/234053/1 "2022-06-27T02:34:30Z")
</div>
I’m new to the Robot Vacuum world. I picked one of these up, and mapped the room, but it was incomplete, but saved. I moved the charger, and then mapped it again. It finished and said it saved, however, when I went to vacuum, the map was still the old one. It is a very large room. So my question is: if I move the charger to a new location in the same room, do I need to delete the old map, and remap the room?
**Author:** ![IEatBeans](https://sea2.discourse-cdn.com/wyze/user_avatar/forums.wyze.com/ieatbeans/32/33378_2.png) [@IEatBeans](https://forums.wyze.com/u/IEatBeans)\
**Post date:** [June 27, 2022, 6:51am UTC](https://forums.wyze.com/t/robot-vacuum-mapping-moving-the-charger/234053/2 "2022-06-27T06:51:55Z")
</div>
I think you will have to delete the map and run Quick Mapping again when making any changes.
**Post date:** [June 30, 2022, 11:07am UTC](https://forums.wyze.com/t/robot-vacuum-mapping-moving-the-charger/234053/3 "2022-06-30T11:07:47Z")
</div>
Thanks for that info. I was hoping if it was in the same room, it would just quickly recognize the pattern, and figure out where it is located on the map. Seems simple enough from a programming aspect.
**Author:** ![purchark](https://avatars.discourse-cdn.com/v4/letter/p/c57346/32.png) [@purchark](https://forums.wyze.com/u/purchark)\
**Post date:** [June 30, 2022, 11:55pm UTC](https://forums.wyze.com/t/robot-vacuum-mapping-moving-the-charger/234053/4 "2022-06-30T23:55:25Z")
</div>
Relocating the charging base is possible, I’ve done it a few times.
> [@Updates to map for robot vacuum?](https://forums.wyze.com/t/updates-to-map-for-robot-vacuum/209265/2):
> It will only save map updates done by a full vacuum. It won’t save for spot cleaning or if any rooms are selected (\*). It also must dock pretty much on the 1st try, seen it too many times fail to save if it takes longer than normal to dock. (\*) I found an odd case where it actually saved a map change after selecting a room to clean. Not sure if it has a meaningful use though. So it can happen. ([2022-05-28](https://forums.wyze.com/t/wyze-vacuum-lost-one-room/253743/9)) For large changes (a new open room) it will ask at the end if you want to save the chang…
