# Robot Vacuum Exclude Hours Controls
**URL:** <https://forums.wyze.com/t/robot-vacuum-exclude-hours-controls/184323>\
**Category:** Probably Not\
**Tags:** robot-vacuum, probably-not\
**Created:** [June 2, 2021, 3:14am UTC](https://forums.wyze.com/t/robot-vacuum-exclude-hours-controls/184323 "2021-06-02T03:14:59Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![Ominous](https://avatars.discourse-cdn.com/v4/letter/o/91b2a8/32.png) [@Ominous](https://forums.wyze.com/u/Ominous)\
**Post date:** [June 2, 2021, 3:14am UTC](https://forums.wyze.com/t/robot-vacuum-exclude-hours-controls/184323/1 "2021-06-02T03:14:59Z")
</div>
Last night I was awakened at 2:00 AM when my robot vacuum finished charging and resumed it’s last cleaning. Please add a way to set “do not run” hours.
> [Mod Edit]: _Title Modified to Enhance Search Clarity._
**Author:** ![cheaplikeafox](https://sea2.discourse-cdn.com/wyze/user_avatar/forums.wyze.com/cheaplikeafox/32/9797_2.png) [@cheaplikeafox](https://forums.wyze.com/u/cheaplikeafox)\
**Post date:** [June 2, 2021, 5:53am UTC](https://forums.wyze.com/t/robot-vacuum-exclude-hours-controls/184323/2 "2021-06-02T05:53:44Z")
</div>
There is also another item on the wishlist that is similar. I agree there should be a time where the robot will not resume cleaning or start a cleaning late at night. I had to remember not to schedule or let my robot clean at night anymore.
> [@Vacuum - Postpone mapping and Cleaning](https://forums.wyze.com/t/vacuum-postpone-mapping-and-cleaning/159433):
> When the vacuum goes to recharge in order to complete the cleaning and mapping, there is no way to actually pause it so that it doesn’t run after charged. This was important because I decided to test it at night, it ran out of charge and went back to the base station to charge. However, I wanted to delay it because we were going to bed when but had no way of doing that. Can a postpone or delay for x hours be made available for the Vacuum, especially when it is mapping while cleaning?
**Author:** ![morgan.croft](https://avatars.discourse-cdn.com/v4/letter/m/e9c0ed/32.png) [@morgan.croft](https://forums.wyze.com/u/morgan.croft)\
**Post date:** [July 10, 2021, 4:17pm UTC](https://forums.wyze.com/t/robot-vacuum-exclude-hours-controls/184323/3 "2021-07-10T16:17:51Z")
</div>
I did try searching. But I was thinking it would be really nice if you could set “do not vacuum” or “do not disturb” hours for the vacuum. So that if you’re doing an evening clean, and if needs to go recharge, it doesn’t try to pick back up in the middle of the night.
Ie, i would set do not disturb hours to be 11pm-7am… and if the vacuum will not try to resume a cleanup during those hours.
