Replacement for v2 Suggestions
Hello -
I have had v2’s covering the exterior of my front and back doors for some time but they are getting a bit long in the tooth. Is there a replacement you could suggest, if I am luck to use the same base.
If not, what wireless option would you move to?
Thanks -
Chad
when you say V2 I am picturing the wired cam that I got into many moon ago, but as you mentioned the base, im thinking you mean the outdoor Cam V2, am I correct that you are speaking to the battery operated ones that work off the base?
If it’s the battery operated one I would highly suggest upgrading to the battery Cam Pro, The fact that you can get batteries for a good price an simply swap them out instead of bringing the whole camera in to charge it was one of my favorite features about that release. And they’re in 2K. There is also now a Solar Pancam as well depending on where your setup is and how much light it might get. But overall I think I still prefer the Battery Cam pro. They are ridiculously useful easy to move if you get the right clamping base and like I said the removable battery is glorious. I keep a battery charged at all times just so I can switch it in and out quickly when needed. there is also no base needed, if you have a good network they pick up the signal very well and have performed great for me!
